James City County / York County / Williamsburg / Poquoson
LEH
Yorktown, Virginia
Do you know of any special tables for this? With my PSR 500, I am not hearing anything. I will occasionally get a stop, but no audio.
what do you listen in York Co.? I have a best friend who knows a sheriif that works for York Co Sheriifs Office, according to him and the wiki they are encrypted. Do you often hear encryption?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Check reband Lynn, lower each CC/ACC by 15MHz but keep P25 Auto as type.
richrowl
Chesterfield Co Virginia
Trunking Tables
I had a similar problem with another TRS, stopping on the TGs but no audio. I had to change the trunking tables from default to custom. You may want to try each of these to see if it corrects the problem CUSTOM DEFAULT SPLINTER
RJY
I just downloaded the system from RR and programmed on my 996T and can't hear a thing whereas I was before. Any ideas?
Not necessarily a radio guru here so take it easy on me :). I've got a 396XT but haven't even tried to work with it yet.
RJY
BUMP
Any ideas guys? Any help would be appreciated.
vanatta
vanatta
For Gloucester county Va., I am trying to program the fire tac talkgroups Tac 1, 2, 3, 4, 5, and I can not find the DEC numbers format to do this..... Only DEC listed is 1322 which is fire dispatch main.. Frustrated -- Where do I go ?
dtscho
Fredericksburg, VA
That's because the only talkgroup in RR is the dispatch talkgroup. We don't have the talkgroups for Tac 1-5.
Dave
