Japan Police, Fire, Ambulance Radios?
What do Japan police, fire, etc use for their radio system? Are they digital? TETRA? Thanks for any information!
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
It all depends on what prefecture you are in. They have a lot of TETRA trunking systems in place for the police. This usually consists of a prefectural network, and there is another network that is nationally based. However, fire and EMS communications are still on VHF-High band in many areas. However, they plan on going digital in the future.
73s
Ron
What does Tokyo Fire and Ambulance use? Digital radio also or old analog still?
mizuki7_lv
Miyazaki-Pref,Japan
Tokyo F.D. is use 260 MHz Digital Radio.
TX Frequency:262-266 MHz
RX Frequency:271-275 MHz
Direct communication Frequency:262.0375-262.4375
Step:25KHz
Modulation scheme:π/4-shift QPSK
Communication method:TDMA
Voice Codec:AMBE+
Until all the systems digitize, Analog radio is also used together.
The radio communications of Tokyo can be heard with the Web radio of this page.
WebRadio3@TOKYO
(TFD call-sign is "Tokyo-shoubou")
