Java no longer viable!
milf
Careful, I CAN hear you!
Indianapolis, IN
The current Java Feed method is no longer being supported. Windows blocks it. It will not work on Windows machines due to the security certificates not signed or properly updated, as well as other issues. I verified this on Firefox, IE8, and Chrome. The system needs to be updated if we want to continue using the Java Option. I even tried changing my security settings, and it was still blocked because of those issues.
NFR85
Ok I think i figurged it out. Heres what you do.
1. Open up Java.
2. Click on Security
3. Click on "Edit site list"
4. Add Broadcastify to the list
Now doing this will prompt warnings saying there could be a risk and just click ignore and then you should be able to play Java.
milf
Indianapolis, IN
TY, somehow the system we use for the java feeds still needs to be updated so you don't have to go through this.
Nasby
Ohio
Anyone know if this can/will be fixed so we can use Java gain?
amduscias
Winnipeg, Manitoba
