JCP&L
DSYCUTTER
Jackson, NJ 08527
IM new to trunking and I am looking for a complete list for jcp&l
preferably in a preorganized list that i can just download through arc250pro
any help would be greatly appreciated
elias1988
Seaside Heights,NJ
Here are the 10 frequencies in the system (KNNM387)
939.175, 936.15, 936.1875, 937.25, 937.65, 937.9375, 937.9625, 937.975, 938.7125, 939.950
HEX ID Uniden ID - Type 2 TALKGROUP ID
41 1040 *Unknown
63 1584 *Unknown
65 1616 System Operations - Morristown
67 1648 Garage
69 1680 Substation - Relay & Testing
06B 1712 Business Office / Meter Department
06D 1744 Forked River Storage / Allenhurst Engineering
06F 1776 Telecommunications (Radio Repair, Etc.)
71 1808 Underground Cable / Dist. Const. & Maint / Cookstown Ops
73 1840 Transmission Construction & Maintainence
75 1872 Express Trouble Center- Morristown (Main Dispatch)
77 1904 Freehold Operating Center
79 1936 Belford Operating Center
07B 1968 Long Branch Operating Center
07D 2000 *Unknown
07F 2032 Hightstown Operating Center
81 2064 Point Pleasant Operating Center
83 2096 Berkeley Operating Center
85 2128 Lakewood Operating Center
87 2160 Toms River Op. Ctr. - No Longer Used, Disp. From Berkeley Ctr.
08B 2224 Zone 2 - Customer Operating Center Work (North)
08D 2256 Zone 1 - Customer Operation Center Work (North)
elias1988
Seaside Heights,NJ
41 1040 *Unknown
63 1584 *Unknown
67 1648 Garage
07D 2000 *Unknown
elias1988
Seaside Heights,NJ
Yeah i guess, i'm also new to trunking, i can't wait until the Pro-2096 comes out :D try entering the 9 frequencies first then do the talkgroups.
DJ88
Brick Twp., New Jersey
It's a Motorola Type 2 900 MHz trunked system. Setting it up in your scanner depends on which one you have. All of the information for the system is posted on the RR Database - New Jersey - Monmouth County.
DJ88
Sorry. I can't help you with programming using software. I program everything into my scanner manually.
BTW I have the BC785d, the base model of your scanner and have the JCP&L System in mine. The Motorola Type 2 800 and 900 System are the easiest to program. Just the the bank, the system type, the frequencies and talk groups. No base frequency, offset channel, spacing, or fleet maps. Doing it manually is easy, but a bit time consuming. Maybe someone can give you some advice about using the software.
nosoup4u
High Bridge, NJ
I have noticed that with the 900Mhz band, the reception is much better if you have the freq.'s setup as NFM, rather than FM.
DSYCUTTER
Jackson, NJ 08527
OK I GOT ALL THE FREQUENCIES PROGRAMMED IN AND SET TO TRUNKED, BUT IM TRYING TO LOG ALL MY TALKGROUPS INTO MY PROGRAMMING SOFTWARE AND IT WON'T EXCEPT THE NUMBERS
EXAMPLE: LONG BRANCH OPS 07B 1968
IT WONT ACCEPT THAT
RIGHT NOW I HAVE THE SCANNER DOING AN ID SEARCH AND IM PICKING UP SOME CHATTER, BUT WITH ALL THIS INFO I HAVE AVAILABLE I SHOULD BE ABLE TO HEAR EVERYTHING
elias1988
Seaside Heights,NJ
Ok no problem, i think the HEX id is for radioshack scanners but i'm not sure maybe someone can confirm that for me? i need to learn alot about trunking before the Pro-2096 comes out.
DSYCUTTER
Jackson, NJ 08527
HEY THANX FOR ALL THE HELP, AS OF NOW I THINK ITS WORKING. ILL HAVE TO WAIT TILL DURING THE DAY WHEN THERE IS ACTIVITY ON ALL TALKGROUPS
