JeffCo on State 700mhz now
#1
Today I'm receiving the JeffCo Trunked System on the State 700mhz Trunked System as System 172. JeffCo user TGIDs are the same. The State system is programmed into my BCT396T using its 700mhz frequencies, but System 172 shows up with 800mhz frequencies.
Hearing it loud and clear in western Jefferson County.
#2
Frequencies:
769.2812
770.3062
770.8562
771.3562
771.9812
772.4312
Birmingham TelVue site:
https://www.radioreference.com/apps/db/?siteId=26415
Edit: I had an 800 mhz frequency entered in the system BAND PLAN that I'm told was causing the JeffCo System to be received on the State System. I don't understand everything I know about it, but I don't have the option of deleting this thread now.
Sorry about that ……… carry on.
#3
FWIW: The Frequencies and Band Plan I was using for the State System was as follows:
Frequencies:
769.2812
770.3062
770.8562
771.3562
771.9812
772.4312
Band Plan:
0: 851.00625/6.25
1: 762.00625/6.25
#4
Admins PLEASE DELETE THIS THREAD
Bad information. I got confused and was using the same quick key for two different systems.
