jmbe files
fellowesman
manton mi
need help
when I run the jmbe creator bat file it runs and closed down in like seconds to fast to read the location for the audio files
any help as to what they should look like or names so I can find the back
thanks
KE8MIR
Reconrider
Inside the Galaxy
Radio Galaxy
It really helps when you give us more info.
What program? OS? What you've tried so far?
I'm going to assume SDRTrunk - you don't need to compile the jar file anymore, simply open settings and click on the voice and create directory(or something along those words) and it will create it for you.
fellowesman
manton mi
yes I am trying to set up sdrtrunk on a windows 10 machine downloaded to jmbe creator and sdrtuunk ran the jmbe bat file
as I did on a windows 7 machine but like posted above it closed to quick
When I unzipped the sdrtunk program it looks like the jmbe creator was incl in it
Reconrider
Inside the Galaxy
Radio Galaxy
“Starting with Version 0.5.0 Alpha 2, you no longer have to install Java and compile the JMBE library. sdrtrunk now has integrated support for creating the JMBE library.”
you just need to go to settings and go to the jmbe tab and click create dir and it will download, extract and compile for you.
fellowesman
manton mi
got it working was trying to make this a standalone system with out having internet connected
you need to be hooked up to internet to down load the jmbe libary
so now it works
