Johnson County Fire 154.010
Indianapolis,Indiana
#1
Does anyone know if Johnson County fire on 154.010 has turned down the power output to the countywide paging network. On Weds 12/28/16 at 8:30AM I heard a dispatch for a call but the signal and audio was very low. Is anyone hearing what I am hearing? Used to hear Johnson County fire very loud on the audio and signal on a Bearcat 300 that I use on my night stand. Very low signal and audio from the Northwest side of Indy.
Johnson County, Indiana
#2
I'm noticed it cut out a time or two also. Maybe 2-3 times in the last month or so. The signal just drops out to a static and it remains staticky until the transmission drops.
