Joint Base Lewis McChord
mkohout
Washington
Hi everyone. Is anyone able to receive JBLM's trunked system on their scanner? I have a 20-164, and afterprogramming it with RR I get nothing. My other trunked frequencies work though.
Thanks!
Wilrobnson
Object-oriented
The database for that system is a bag of worms. JBLM's 14C system is seperate from the USN/USMC 14C system in the region; you can see this for yourself by looking at the control channel neighbor broadcasts.
The JBLM system is 4 sites, 1-3 at Lewis and 9 at McChord, P25 exclusive.
WAScanMan
Thurston County, WA
Down in Thurston County I am unable to pull this system: Joint Base Lewis-McChord Trunking System, Tacoma, Washington - Scanner Frequencies
However, I can recieve the DoD system( U.S. Department of Defense: Project 25 Trunking System, Various, Multi-State - Scanner Frequencies )
The DoD system has the MP's, fire/ems, gate guards, range control, Grey AAF maintenance units, as well as other miscellaneous base ops TGID'S. I have a fairly extensive list of TGID's from unattended logging in pro96com if you want them. (Once you get a digital scanner of course) Hope this helps!
