Jt1000 dtmf
cheld18
Pleasant Plains, IL
I Today I got a chance to sit down and play with my Motorola JT 1000. One feature I have a question with is the DTMF option. The DTMF option on this particular radio is enabled using the orange (emergency) button on top. However, when I depress the button, a 4 digit DTMF access code is transmitted, then I can use the keypad on the radio to transmit more DTMF tones if desired. My question is does anybody know how to silence the access code, and if so, how?
KG4INW
Midlothian, VA
Yes, you have to use the RSS to delete the access and any de-access codes that are associated with DTMF. Unfortunately, this can't be done from the keypad but once it's done, you won't be transmitting anything you don't want to.
