newbiescanner said:
OK so do I need to take this scanner in to get programmed? This is my first scanner. I live in Davidson county. I cant hook it up to my laptop because their is no connection other than usb on my laptop. Is their another type of link in need? Thanks for any help, ready to play with my new toy!!
It's easier with software but all is not lost -- I assume you want to listen to Davidson County Public Safety (trunked system):
Turn the radio on
Hit the MENU button (lower half of the black pad of the left side)
"Program System" should be displayed
Press E/yes (enter)
Using the knob on top, scroll to "New System" and press E/yes (enter)
Scroll to "MOT" and press enter
Scroll to "800Mhz Standard" and press enter
Confirm by hitting enter
**for now, leave the name as "System XX" - just remember the system name (you can change it later)
Scroll to "Set Frequencies" and press enter
"New Frequency" should be displayed - press enter
NOTE: ** you are now entering the system control frequencies **
NOTE: ** RadioReference lists 4 of them ***
enter 856.4875 and press enter
the display should now say "Edit Frequency" ... ignore that...
Press the MENU (side button) to go back to enter the next frequency
Scroll to "New Frequency" and press enter
enter 856.7125 and press enter
enter 856.9875 and press enter
enter 857.2625 and press enter
Press the MENU (side button) to go back as if to enter the next frequency
Display should now say "Set Frequencies"
Scroll up to "Edit Sys Option" and press enter
"Set Quick Key" should be displayed... press enter
Scroll and select the Quick Key value you want to use for this system (say, for example, 5) and press enter.
Press scan (the new system should automatically be "active" but if it's not, press the 5 key on the keypad to activate it.)
The 2nd line of the display should scroll the message "ID SEARCH" or "ID SCAN" ... since you haven't programmed any "talkgroup ids", you must be in "ID SEARCH" mode. If the display says "ID SCAN", press the SCAN button a couple of times until the display reads "ID SEARCH"...
As new TGIDs pop up, I think you can hit E/yes (enter) to save them on memory ...
If you're already past this point... it was fun anyway...:lol:
