S
simpilo
Guest
Suppose we try to monitor a HamDMR repeater with just using FMP24 and DSD+ using the TCP internal port. I have not seen this mentioned yet. Doing this without virtual cables. What would we do to make it work?
Just manually tune FMP24 to the DMR repeater output.Suppose we try to monitor a HamDMR repeater with just using FMP24 and DSD+ using the TCP internal port. I have not seen this mentioned yet. Doing this without virtual cables. What would we do to make it work?
Simplio,
You can download the ham DMR data from https://goo.gl/BGYdv4 . You could add the data within this file to your DSDPlus.radios file. Then when you are monitoring the ham DMR systems you can easily tell who the operators are.
You should add all of the ham DMR data to your DSDPlus.radios file. That way, you see everyone's name and where they are.
Do you do this without using SDR Sharp? I have been able to use FMP24 by itself, but only to monitor FM like NOAA weather, but what do you have to do to monitor DMR? Have you set up a batch file? What does your FMP24.cfg file look like?
Thank you simpilo for your help. I got it working just by changing the port from 40002 to 20002. Plus I got an error message about "lame_enc.dll" missing, so I downloaded that and put all this into a folder, and it's working.
Simplio,
Can anyone assist on adding this to my radio records file? When I copy and paste the list in, DSD creates a fresh list as soon as the first DMR transmission is received and wipes out the list I copied in.
How do I get this file to show as DSDPlus.radios file in the DSD folder? When I extract it and replace the existing file, the new file shows up as a txt file then DSD creates a new radios file upon the first transmission received and ignores the file I put in there.
