motouser
- Joined
- Sep 2, 2010
- Messages
- 8
Hey guys! Im new here and just got a good deal on a clean TK 760H and 860H pair.
They do not have the microphones, which i will need to locate.
They are already programmed for the appropriate bands i need, but i want to program the channels to the exact order i need them to be in. Are these able to be front face programmed, or should i locate the programming cable and software for Win XP?
The 860H is setup already for Type 1 band 450-476, which i will use with my GMRS license. The 760H is setup for Type 1 148-174. On the 760, what type of antenna connection is on the back of the unit. I know the 860 is the regular UHF connector. Does the 760 use the same connection type? There is not a clear picture in the manual or online?
I found a manual for the 760H, but not the 860H. Are they pretty much the same with the exception of their bands/freq?
Also, what mic should i look for? KMC-23 with the built in keypad?
Can't wait to get started! Is there a way to make a dual band setup (paired) like the 730-830 can?
