Just received RTL-SDR Zadig not seeing device.
#1
I downloaded SDR# from Airspy
I ran the install-rtlsdr.bat file, after that finished I found zadig.exe and rtlsdr.dll as I expected so I assume that part worked correctly.
I plugged my RTL-SDR RTL2832U into USB port, ran zadig.exe as admin, selected "Bulk-In, Interface (Interface 0)". But I don't see anything listed for Driver, that box says "(NONE)". I have confirmed the rtlsdr.dll file is in the same folder as SDR# & zadig.exe.
I'm having this problem on Windows 7 and my Windows 10 machine. What step did I miss?
#3
I got it working on Windows 10, not sure how but you don't select "Bulk-In, Interface (Interface 0)" as the RTL-SDR website says, you select RTL2838UHIDIR.
However I still can't get anything to work on the Win 7 machine. When I plug the RTL-SDR in the USB port windows tries to install a driver but fails everytime. Then Zadig doesn't show anything close to an RTL device....
adcockfred
Aldine, tx.
#6
Try bringing down firewall, domain too, inbound outbound rules. See nothings running in back ground using said port. reboot !
