I just upgraded the OS on my PC to Windows 10. I am using Scannercast to broadcast my feed. I have my scanner plugged into the PC through the line in outlet on the sound card. When I first restarted my PC, I could hear the scanner fed through the PC speakers. I don't want that. Then I found out not only am I BROADCASTING my scanner feed, but everything else I play on my PC. I worked to adjust the setting in the PC and I got the scanner feed of the PC speakers but could not get the PC to stop broadcasting everything else along with the scanner feed. I used the Windows audio troubleshooter. Now my stream isn't broadcasting but things Youtube broadcast with no problem. I am at my wits end.....
