kalispell FBI frequency ?
Libby, Montana
#1
Hi All
has anyone heard any FBI comm's on 163.9375 mhz ? I picked up an agent passing through Libby on that frequency awhile back. I think the PL tone was 100.0 which I thought was kind of weird as the normal tone the FBI uses is 167.2. He was talking to a dispatch lady. Nothing serious. Have not heard anything since.
I think he was using an moblie repeater.
Taxachusetts
#2
163.9375 would be an input
However the FBI has long moved to P25, generally $167 for the NAC, but the PL was 167.9
100.0 would point to me, you likely were hearing a Canadian user (different band plan, not 12.5 Khz) or an image from 152 Mhz (depending on your scanner make/model)
Hi All
