Kennecott
kirkco
Erda, Utah
#1
I have not been able to pickup anything from Kennecott (including DMR) and I am just on the Tooele County side of Farnsworth Peak. Seems I'd at least be able to pick up DMR with my SDS100. I don't have a problem with other local frequencies. Can anyone please share some tips and tricks for Kennecott?
Utah County, Utah
#2
kirkco
Erda, Utah
#4
Thanks Chris,
I think my "problem" for picking up anything (DMR specifically) is that I live on the West side of the Oquirrh mtn's sort of under Farnsworth Peak. Even though the coverage map shows the range of covered area exceeds my area (Stansbury/Erda) the proximity to the mtn and tower is blocking the signal. I can go around to the other side..say in Magna... and can receive some communication.
