Kentucky State Police
#1
I posted a thread last week about the KSP, I am about to go on my trip
through Kentucky, so if I want to listen to KSP do I need to program them
as Conventional or motorola 800 Standard or what do I use for the
correct setup. Bowling Green, Elizabethtown, Louisville are the area I will be
passing through. Uniden 396T scanner
Glasgow, KY
#2
KSP is conventional. All you need to do is type in the frequency and bam you've got it. Best I can remember Louisville is also conv.... I believe Etown is conventional also... and Bowling Green is Motorola 800 Standard Trunking.
