Kenwood 2312
rescuefire12
LaFollette Tennessee
I have a Tk 2312 that was already programmed and I now have the program software and cable. I added a couple of new channels but they are not working correctly I can not here anything on the new channels unless I push the monitor button on the radio and hold it I know the channels and tones are correct.
Well Known Member
SNCZCA01DS0
Do you have the channels programmed for "narrow" deviation? If you have it set to wide, it may cause this issue.
Also, while they may be using a CTCSS or DCS tone on the TX side, they do not necessarily use the same one, or one at all, on the RX side. Try setting the channels to CSQ (carrier squelch) and see if it works correctly.
