Kenwood NX-200 Caller ID
jhampton2000
Can someone help please configure the Caller ID settings on my NX200......
I would like to be able to scan multiple NXDN conventional channels, display Caller ID on each channel when a signal is received, but critically on close down of the call it should display the channel upon which the call was received before reverting to scan again. At the minute my setup displays the caller ID ok, but then immediately reverts to Scan - so I don't know which channel the call was received on. It seems like I need to set a 'dwell' or 'hold time' setting before reverting to scan, but I can't find anything suitable?
The behavior I want is similar to that shown in this video:
Some NXDN! - YouTube
At about 42 secs, the display goes from 'UID 994' to the 'Canton NXDN 3' channel display, before reverting to 'Scan' (I can't get my NX200 to show the equivalent of the 'Canton NXDN 3' display before reverting to 'Scan'). Anyone any ideas?
TIA
Jim
ramal121
Sonoma, CA
The auto reset timer ( NXDN GENERAL 2) controls how long the ID is displayed and the LCD box is checked. This time must be less than the scan dropout delay.
Sent from my Nexus 7 using Tapatalk
jhampton2000
Thanks ramal121 - I'll try that.
It had been set with default 10 secs (auto reset timer) and 3 secs (scan dropout delay) which probably explains it
