Kenwood nx 5300 battery not charging
jperuta
Wethersfield CT
Good Evening all,
I have a kenwood Nx5300 uhf. I have 2 batteries that I have Been using since I got the radio. All of a sudden one battery Doesn’t want to charge. It will flash red while in the charger. The battery is either by itself or connected to the radio when I try to charge it. Ive Tried cleaning the contacts but the problem is still there. Does anyone know what that might mean? Or how to fix it with out buying a battery.
thanks in advance
Battery may be shot.
How old are they?
There are internal components in the battery that can fail, other than the cells themselves. If your other battery charges just fine, but the other one doesn't, it means your charger is probably good.
Batteries are sealed and opening them up is a real pain in the butt verging on impossible. There's no easy fix. Buy a new battery.
jperuta
Wethersfield CT
How old are they?
Unfortunately
I think the battery is like 2-3 years old at the most. I’m kinda surprised it has failed already
Yeah, it's early for it. I'm running a few hundred of the 33l batteries that are well over 7 years old without issues.
If it gets really cold where you keep it, that can damage them. There is an internal temperature probe that will keep them from charging if the battery is too cold, also.
