Kenwood NX-800 Programming Help Please
jmedinac
Hello All!
My tiny local radio shop went out of business because the owner passed. The owners kids put all the stuff for sale in an estate. I acquired 4 Kenwood NX-800's that are read and write protected from the estate sale. I do have the "Engineer" version of KPG-111D v1.40, I am just unaware on how to retrieve/rewrite or wipe the password. Any help would be greatly appreciated.
Best Regards
Jeremy de N2UGS
paulears
Lowestoft - UK
The engineer version doesn't pay attention to passwords at all - you can read and write and reset any password present. You should be able to simply read the radios and delete the passwords, or put new ones in. If you cannot, then you don't have the engineering version.
Vern
Union County, GA
It's been a while since I've used it, but as I recall, here are the basic steps:
1) Write down radio's model and serial number (especially for portables).
2) Connect radio/cable/computer, run the KPG software. Set com port.
3) In software, on MENU BAR, select TOOLS, then select TRANSCEIVER INFORMATION. After it reads from the radio, note the model # and other details.
4) On MENU BAR, select MODEL and make sure the spaces for model, band, options match you radio.
5) On MENU BAR, select TOOLS, *Password Reset (If that option doesn't show on your TOOLS menu, you probably don't have an Engineering version of the KPG software.)
4) In the *Password Reset window, enter the serial number, check the 3 boxes, then click "OK".
5) On MENU BAR, select PROGRAM, then EXECUTE PASSWORD RESET.
If you get an error, you might have a version of the KPG software that's too old and doesn't match the firmware in your radio.
Best of luck with it.
jmedinac
Thanks for the help! I was missing the execute step. All good on the NX-800 I'm now having an issue with the TK-8180-K2, I am unable to enter the serial number that starts with a letter (B), rather than a number, the software wont allow letters. I am able to read the radio without issue but it asks for a pw when writing. Sorta stuck on this one this evening...
Jeremy de N2UGS
Alexnorth
Hello I have the same issue with a nx-800 i purchased on internet but i cant found the engineering key for KPG-111 can someone help me please i searched like 2 hour on internet ...
19sargeusmc56
Anyone got a wiring diagram for the accy jack programming cable? I understand if you program the radio that way, it bypasses passwords.
I have a whole bushel basket full of password protected fleet pulls.....and I don't have engineering software.
Mikey69
Look at the schematic in the service manual and see if pins 2 and 3 are labeled as serial data and 7 as ground. I've been able to make up a 2, 3 & 7 serial cable that plugs into the DB9 on my Toughbook laptop and have it work on the NXR-810 repeater.
Mike WA6ILQ
