Kenwood nx200 K programming
#1
I have a pair of kenwood nx 200 i would like to restore to factory default settings, so i can sell.
i have KPG fpu 4.8 and programming cable
where do i start?
I would like to delete "custom greeting" when the radio is turned on, and leave the radio "unprogrammed"
thanks for any help
The great state of Tennessee
#2
Open Up the software
select your comm port
read radio
delete your frequency information
under edit optional features optional features 1 page you will see the custom message towards the bottom right.
then write it all back to the radio once you have deleted what is in the radio
depending how your radio is set up you may have multiple zones of frequencies
#3
Ok,
"Com port cannot be opened" is the message I received,
Not sure if this is a windows 7 issue (which is what I'm using to program)
Firmware 4.61.00 is current on my radios and I use KPGFPU 111D v 4.8
Thanks again for any help.
Point Nemo.
#4
I'm using KPG-111DN 4.8 with NX-210's, 410's and 900's using Windows 7.
Make sure radio is on and you've got the right comm port set.
You are OK with radio firmware and software firmware.
#5
thanks for your response, this particular laptop doesn't have com ports that i can find,
i am going to use a different laptop this weekend with Windows Xp, unsure if that has com ports or not.
Point Nemo.
#6
In the "Settings" tab there is a selection for "Comm Port". If your cable is plugged in and it's recognized, it should light up on the comm port option screen.
I've got an old XP machine I run the latest version of KPG on that has a true DB-9 port, but I use the USB cable with it. Never had an issue with either machine with the USB cable.
03msc
Arkansas
#7
Click 'start' on Windows and type device manager and then click on it. Under COM and LPT Ports, see what, if any, are listed. If none are showing, it isn't recognizing your cable. If it shows something with a yellow exclamation point there is an issue with the cable or driver installation.
