Kenwood NX3820
Liverpool
Just got a bunch of radios thats I am trying to program. However I am unable to read or write to the radios. When hitting read or write using KPGD3 software the radio switches from unprogram to program but then after a while of doing nothing the software says failed to communicate.
Am i missing anything? Is there anything special with the cable?
thanks
What's the software version?
What is the radio firmware version?
Which cable are you using?
Same with all the radios?
If everything is working right, it should just work. There isn't anything special you need to do.
Hiya software version is 3.00 and release 6/27/2019
Firmware is 3.52.00
cable is kpg-46 same as I have used on nx-800
thanks
I'd have to do some digging, maybe @kd4efm can confirm, but there was a big change in the software/firmware mix that had a requirement to update your software if using something above a 3.4x version firmware.
In other words, you need to update your KPG-D3N to make this work.
Cutoff seems to be the 3.2 version. Since your radios are newer, upgrading software should fix this.
Contact your Kenwood dealer for the updated KPG-D3N software.
@kd4efm, can you confirm I'm on the right track here?
natedawg1604
Colorado
So I have several 3720's with version 3.5 firmware (I believe it's a few versions behind). The Software is KPG-D3N v. 3.30 (It says released in 2020 but I bought it recently so I believe it's current). I've never had any issues, and I mess with the programming frequently.
Thanks, that matches up with the 3.20 thing I recall. I found some documentation on it, and it confirms, but just wanted to double check with Evans since he's the expert on this stuff.
Liverpool
Thanks for your replies. I have since contacted our dealer who has provided me with Version 3.6 and is now working.
anyone got experience with KAS-10 and base radio settings for this?
thanks
Liverpool
Unable to get any communication via pc and radio. Running in dmr mode, have pc to radio cable from dealer, com 1 set and data and gps on mobile software
n0fwg
Minnesota
Radio firmware 3.20 & older can only be programmed by KPG-D3N ver 3.20 or older.. Once you upgrade KPG-D3N to Ver 3.30 or greater you loose the ability to program the older radios unless you update the firmware. You can only install one version of the software on your PC with the license key. in short there is brick wall at 3.30 that separates the versions.
If your trying to use KAS-10 with the NX-3820 you need to modify the 0 ohm chip resistors on the main board for serial comms via the rear DB15 port. These are 0602 chip resistors so a microscope is recommended otherwise you will go insane!!
Then you have to set one of the radios comm port for serial data, I do not recall what the exact options are.
