Kenwood NX5000 Series Lockout
jasej
Hidalgo Texas
Hi my friends
What if _
Have a NX5300 Radio with a LOCKED word on Unit Display
What possibilities do I have?
On NX5000 series common funtion PDF manual, says the follow..
If the password authentication fails consecutively for the number of times configured in Password Entry Limit,
the transceiver enters Transceiver Lockout Mode, and then “LOCKOUT” appears on the display.
In Transceiver Lockout Mode, the transceiver cannot be operated.
Also, a failure in Overwrite Password authentication counts as a failure in the password authentication.
** The number of failures in the password authentication is cleared by one of the following conditions:
1 * When the transceiver is turned OFF and then turned ON again
2 * When the correct password is entered
3 * When configuration data is written to the transceiver by using KPG-D1/ D1N
In all of the above, do I need the correct password?
or in at least one of the previous options, I do not need the correct password ?
I have the correct password, but I don't want to make any mistake that will lead me to not recover the equipment, to continue using it.
Thank You
jasej
Hidalgo Texas
Correct password and original dat file for said radio, write to unlock.
i have the correct password, but no specific or saved .dat file for the specific radio...
I was thinking of removing the lock using a blank .dat file, with its correct password, when it asks to write to the radio.. I hope it's enough for me..
Thank you my friend
kd4efm
EL98 Florida
Thank you my friend
that will also do it.
jasej
Hidalgo Texas
Ok my Friend
Finally, to make this clear, in all the options I have, I need a correct password, okay!
Well, thanks again Evans
To everyone on the Forum, have a great start to the week, bless you all!!
