Kenwood Programming software
eastman206
Eastman, Georgia
My question is.....Kenwood has a lot of different programming softwares, does anyone have a list of what programming software programs what radios?
My main interest is the tk-790 but I also have a need for other raidos so I would like all of the different programs and what they program.
Any help would be greatly appreciated.
ambdrvr
Kenwood Software
Here, this should help you out!!!
  • Read Me.zip
eastman206
Eastman, Georgia
kenwood programming
Thanks for the reply but can you send it another wya or tell me where to find this information....sorry but I don't have a program to unzip this file.
RolnCode3
Sacramento/Bay Area, CA
I don't know about other radios, but I have the KPG-44D software and it's for the 690, 790, and 890 (although I have only programmed a 690 with it).
smfdff
Sacto,California
Re: Programming the TK-790; Does anyone know if you can program it with freqs that you can monitor like is was a scanner?
mrweather
If I understand the question you want to program in frequencies that you only want to receive and not transmit on?
You can do that. Simply enter the frequency in the RX column and leave the TX column blank. If you try to key up the radio it will give you a tone and won't transmit.
smfdff
Sacto,California
Yes. You understand correctly. Just want to play around with an old TK-790 I have around but did not know if that was possible. Looks like the correct programming cables are around $100. If I remember correctly, the old programming has been cleared by the previous LEA. Is the software user friendly; meaning I should be able to connect the radio, start the application software and follow instructions? First radio programming. Looks like I have KPG-44D v.1 software.
Thank you
mrweather
If you've entered data on a spreadsheet before you'll have no problem using the software. I find KPG-44D much more user friendly than Saber RSS.
