Kenwood tk 2180 fleet sync
CvBballer09
I just added all the id's to the list. It is set for my county fire channel but the only thing I hear comming through it is the radios on my Id list. And sometimes it doesn't even show the id. If anyone could help it would be greatful. Thanks
Two things to check for:
1) under the FleetSync window, check (or change) the baud rate
2) check (or uncheck) the FleetSync II setting.
You may have to play around with these settings depending on how your system is setup.
Hope this helps
CvBballer09
I finally got it to work but it won't scan and show the Id name. And the channel is all static.
