Kenwood tk 2180 programming help
jw_simpson
Has anyone out there ever programmed a kenwood tk-2180 vhf for first responders/ scanner? If so. I NEED HELPPPPPP!!!! Let me know who might can answer them please
kayn1n32008
ØÆSØ
Sector 001
There is a bunch of us with Kenwood TK/NX experience. What are your questions?
jw_simpson
I have zone one programmed like this. With these frequencies. But when I wrote them to my radio and turn it to the Channel. All I hear is static
Giddyuptd
Here and there
The tk 2180 is pretty easy to program as a lot of kenwoods. Ask away and your questions will be answered by several.
Giddyuptd
Here and there
Well let's see if it's something easy, noticed you are using csq on all of them, unless you change the tones for the pic, check your squelch setting see if it's below 3, or 5. If it's at 1 you may be getting interference in csq near electronic equipment or routers, car electric system in cab. Try a dummy test and put a tone in all the rx channels and see if the static remains, If it remains check your squelch settings and get it off 1 if you don't use a tone. 3 or 5 should be ideal 5 being default. If none of it fixes the issue it'll be the sj-180.
kayn1n32008
ØÆSØ
Sector 001
Been messaging the OP and it turns out a bunch of what he wants to listen to is NXDN, and his radio is not capable of NXDN. Squelch is not an issue. He is hearing the digital transmissions which sound like static.
