Kenwood TK-2207
Ontario, Canada
#1
Just purchased radio on line from China to add to our vhf portable collection for our fire department in Ontario Canada. I am able to to connect and write and do any programming I need but I am not having much luck in making the radio work after I write to it. Initially I had a tone when I turned it on and a audio channel # voice when I switched channels. After writing to it, I no longer have either. Have tried to update radio to our fire department freqs but unable to transmit or receive. Tried to also enter weather freqs but no joy on listening. The led light comes on for receiving but no volume. I am using kpg48d software and everything appears to work for programming but in the end, radio does not work. Any direction would be appreciated as I do not want to add to my paper weight collection.
Ontario, Canada
#4
Will Try kpg 87d
I will try the new software you recommend and post screen shots of my results. Am I able to put a rcv only freq ie weather on my portable? When I input the freqs, Do I input them as same freq for tx and rcv?
