Kenwood tk-2312 programing
Emtblake1989
I have a Kenwood tk-2312 along with the programming software I programmed from wideband to Narrowband and now trying to do the following: Our dispatch channel is open so I hear all dispatches in my area, I want to close it and have it open only when my tones are set off. Dont want to listen to other dispatches.I cant find in the software where I can do this option. Anyone can help?
cabletech
Puget Sound
You are useing the KPG134D software, correct? I have not recieved my copy yet, but if it is any thing like most of the rest of the Kenwood software, read the radio, then go to edit, select 2 tone, input the information under the decode screen, then on the channel information select the channel, go to the right and under opt signal select the 2 tone option that you used.
This is fairly standard in all the kenwood programs.
Emtblake1989
Yes I have that all set up that way yes that is the programming I have. It is all set up that way but still the channel is open alert goes off when tones are hit but channel is still open. Let me know when you get your software and all that and see if you can see whats what. Thank you for your help. still having issue and up for any suggestions.
Avery93
AL
You will need to perform one extra step to make the radio remain muted until the correct tones are received: In the "Zone Information" screen, click "Zone Edit" and change "Audio Control" to "QT/DQT and Optional signalling".
This requires the radio to receive the correct QT/DQT and the correct paging tones before it will unmute. Note that this is a zone wide setting so all channels in the zone will be effected by it if they have optional signalling enabled.
Emtblake1989
I will try that thank you. If I recall I did try that I will try it again and I will see if that works I know I did something where the channel was closed but it set it off with my tones and I know the tones are correct.
thank you again.
