Kenwood TK-270
N2AL
Tennessee
Good Afternoon Everyone.
I am attempting to program my Kenwood TK 270 portable radio, and I am not able to get the correct software to work with my computer. I am using kpg27d which is DOS based. My new computer is Windows 7 64 bit and it will not work properly. Can anyone give me some advice how to make the software funtion properly?
BirkenVogt
BirkenVogt
You have to use DosBox or there may be alternatives. But it can be risky, I have been told, as a hiccup while programming certain radios has been known to brick them. I don't know if this is the case with a 270. You have to set the virtual com port that the program expects to the real number of the com port of the actual computer. Even then it has been known to not work. Radio shops keep dedicated old computers around for programming these sorts of things.
methusaleh
New England
Concerns with bricking this radio using a DOS emulator as mentioned above...if I were you, I would send it off to someone who knows how to program it with proven software, have them modify it for field programming, and just program it that way.
BirkenVogt
BirkenVogt
I will add that I have programmed lots of old Kenwood and other radios with a DOS emulator and never had a bricking problem. I suspect that it might be a Motorola issue and Kenwoods are not suceptible to it, but I have no way to verify.
