Kenwood TK 3180 Programing question
BenSkerker
Attleboro Ma
I am trying to Program my Kenwood Tk 3180 with the UTAC Channels for RX i Put 453.2125 and for TX i put 458.2125 with a pl of 156.7 on the QT/DQT DEC and QT/DQT ENC do i leave the power High and for the Opt Signal what do i change that to Also would i do the same thing for this frequency 471.600 Mhz but the DPL is different. What exactly is the OPT Signal
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Opt Signal is optional signaling, like 2-tone (Motorola Quik-Call II), etc. High and Low refer to the power level. Put in what you're licensed for. IIRC high power is 4-5 W and low power is 0.5 to 1 W, but it's programmable.
If you hit the F1 key, your help file will open and explain all the fields.
Leave the Optional Signaling off unless you have been specifically instructed to program that. The additional noise is just annoying for everyone else.
Jay911
Optional Signaling is not whatever you think it is (PTT ID, etc). It's signaling which is used to either (a) optionally send an alert to a user of a channel or (b) cause the channel to become unmuted only when receipt of the signaling in question is received.
