Kenwood TK-3180 UPG ERROR
Jakethesnake209
I tried giving my tk-3180 a firmware upgrade and when you turn the radio on it just says upg error. Is there a fix to this i cant get it off this screen?
kd4efm
Florida
What cable, what speed, and does it give it in the middle of the upgrade?
What firmware version are you pushing?
Sent from my SM-G965U using Tapatalk
Jakethesnake209
Im using a cable from my fire department we bought. Im at 115.200bps and it wont even let me try to upgrade anymore. It says its v335 for the tk-3180
kd4efm
Florida
V3.35? Cant be. Unless your radios are MPT, then your shoving the wrong firware.
Tk2180K_7180K_V122_035C should be this.
kd4efm
Florida
Are you putting it into firmware programming mode? If so, start the process over from the beginning.
kd4efm
Florida
Use the right firmware and reload it. If it wont take, needs to go to depot. Its bricked.
Jakethesnake209
Okay so the radio wont let me put it in firmware programming mode? Did I completely mess the radio up??
kd4efm
Florida
Let me ask a very important question
Are you using anything other than a windows PC? Mac, parallels, a virtual machine, anything not native windows?
kd4efm
Florida
I dont have my 3180 anymore but you should be able to press and hold the A button and power on for firmware mode. That or a side button. I fogot, but it should come up and say Prog 115,200
Jakethesnake209
Yeah its actually the S button but its not letting me do that anymore. So at this point I'm not sure what to do.
kd4efm
Florida
Send it to your local kenwood dealer for depot repair.
phillmobile
bridlington, uk
upg error means your putting the wrong firmware in, for example if i add mpt1327 firmware to a radio that does not have a license in it, nothing to do with speeds or cables (in my experience)
You might have a k model putting e version firmware in for example
more info may assist
phill, uk.
n7maq-1
Oregon
Look at the flashprom details from the manufacturers (should be Amtel IIRC) but you should be able to short pins 23, or 24 to ground or maybe both (it has been a few years, please check the speck sheet) and that will allow you to program in the firmware with Fpro as long as the flashprom is good. I have used this method several times to get past errors or PassPort firmware. You normally don't have to go this far for just the MPT firmware, that will overwrite with FPU. Worst case is you replace the falshprom and start from scratch, but could be a few hours with a service monitor.
n7maq-1
Oregon
OK, I took a look at my notes, you will want to short pins 23 and 25 to ground on IC500 (AT29C040A-90TI) on the main TX/RX board. Then power the radio on and FPRO should work.
Jim
blong722
tk-2180 reset
Jim
do you happen to have a picture or some other reference on how to do this reset, i have also flashed the wrong firmware to my radio and have gotten the error and it will not allow me to go back and reflash the correct firmware.
