Kenwood TK-7160 and TK-5720
Sidney, MT
I have Kenwood TK-7160's and TK-5720. I had them programed with all my channels in one zone but have recently split them up into different zones to help with switching to different channels as I need. At the same time I added priority to my main channel as I was having trouble having it pickup off of scan as my guys were trying to transmit to me. Since I have done them 2 things now when I'm picking up transmissions it is (gonna try to descried this) it is very in and out per say maybe even choppy and very frustrating to try and listen to. So I wasn't sure if its doing that trying to go back and check on my priority channel or something else I should try and adjust. Any thoughts or suggestions??? thanks
ramal121
Lots and lots of watts
Calif Whine Country
If you're receiving on a channel that is not a priority then yes you are hearing the audio holes as the radio checks the priority channel. Some radios can do this very quickly and is not too noticeable, but others there is a hole as wide as a barn door. Try playing with the Lookback Timer A to find a balance between very broken reception and late (missed) priority traffic. My preference is 0.9 seconds.
Sidney, MT
thank you for that what does the lookback timer b refer too?
ramal121
Calif Whine Country
Good question. If during channel priority scan there is activity (carrier) but the QT/DQT does not match the radio assumes there is another co-channel user not associated with you and switches to Lookback Timer B until the channel clears. A should always be shorter than B.
Sidney, MT
Is there anything I could of done to help with picking up my main channel while scanning without making it a priority. There was times I was testing it before making it priority that I’d test for 30 seconds and it never did seem to pick it up
