Kenwood TK-7160H-K
Radioguy789
Ontario
Hello. A friend of mine has a TK-7160H-K he wants to get programmed and just wondering what software do you use to program it, is it KPG-99D or is there another out there to use to do it. So I will know which one to use.
Let me know.
tweiss3
Is it time for Coffee?
Ohio
I believe you are correct on the software, it is KPG-99D. You do need the software to program that radio, no way around it. The cable can either be purchased from a Kenwood dealer, or a good aftermarket option that has always worked for me with many commercial radios is bluemax49er.
Radioguy789
Ontario
Ok thanks. I have the software and both cables a USB one and a COM1 cable.
Just wanted to check to make sure this was the right software or if there was another one out there to use.
And I have the software on 2 computers a windows 10 and one with Windows XP
Radioguy789
Ontario
Ok now just trying to read the radio and I am having this issue:
ERROR
Check all connections and COM port settings.
I checked that and the right COM port is selected. I am using a USB cable, which I use for other Kenwoods and no issues.
So I don’t know what the issue is.
If anyone can let me know.
KPG-99D is the correct programming software for that radio.
The KPG-46U is the correct cable for this radio, make sure you have the correct comm port set in the software.
Radioguy789
Ontario
Yup that I do I have the right one set up and still nothing. So I dunno maybe it has to do with something where you plug the mic and programming cable into, something is not working there. I dunno. I don’t repair radios. So I don’t know much if it has something to do with that
