Kenwood TK-7160H & Kenwood TK-7360HV Programming Help
KI5IRE
Dallas-Fort Worth, TX
I just received a Kenwood TK-7160H and a Kenwood TK-7360HV and am looking for help programming these radios to monitor analog conventional systems in my area for work.
What softwares do I need for these radios and what cables do I need? Also where can I purchase what I need? I've programmed TYT and Baofeng radios for monitor-only, but this will be my first time for Kenwood so I am not sure if it is the same or not for these commercial radios.
Thank you for your help.
danielxgame
calgary
MAYBE YOU SHOULD TRY IN 7160- KPG 99D IN 7360- KPG135D ABOUT THE CABLE YOU CAN BUY AFTER MARKET AS LONG CAPABLE IN KENWOOD
For the TK-7360, KPG-135DN, latest version is V2.21 for US/Canada market radios.
As daniel said, KPG-99D is the software for the TK-7160 US/Canada market radios.
If your radios are from "somewhere else", you'll need to track down the correct software for the region.
The only legal place to get the software is from a Kenwood dealer. Software is copyrighted. The KPG-99D is no longer available on the dealer tools page, it's too old. KPG-135DN is still available.
But with careful searching, you can often find it from "other" sources. You not only need the programming software, but you'll need an activation key for the software, so if you go fishing around on E-bay, make sure it includes the activation key.
As for the programming cable...
KPG-46A is the RS-232 DB-9 cable that connects to the mic jack for programming. KPG-46 is the RS-232 DB-25 cable. You'd probably find that the KPG-46U USB cable will work, but I don't have a 7160 here in front of me to confirm that. For the 7360, Kenwood says the KPG-46 cable with the KCT-53U USB adapter will do the trick. You can experiment with other USB - RS232 adapters.
Some of the after market cables are OK, some are pure junk. Kawamall on e-Bay tends to have good stuff and good reviews. Avoid the overly inexpensive stuff.
westcoaster
This is the cable I have.
I have an aftermarket USB to DB9 usb adapter, then a DB9 to DB25 serial cable then the KPG-46 with a 6 pin RJ12 crimped on the end.
I confirm this setup works on TK-7160, TK-7180, TK-7360, TK-760G radio's. If I ditch the USB to serial adapter, and change to an old DOS computer, it works on the older TK-760/762 (non G) radios.
