toastycookies
Just got a TK 7360 installed that I am planning on using with digital modes (mainly using FL Digi) on 2 meters.
I plan to use a SignaLink USB between the computer and radio and would like to connect via the TK 7360's DB 15 port.
I have the KCT 60 DB 15 to molex cable.
Should I just get the unterminated SignaLink cable (SLUSBNC) ?
Which pins go where?
And if so where do I get the molex pins to crimp onto it so that I can connect it to the KCT-60 molex plug?
Thank you.
TK-7360/7360H/7360H(V)
Pin Name in /out description
1 SB O Battery voltage output. 1 amp max
2 IGN I Ignition sense input, 16.0V max
3 PA O Speaker output
4 DETO O FM detector output, 500mVp-p
5 DATAI I External transmit signal input, 200±50mVp-p
6 FNC1 I/O Programmable I/O (programmed by FPU), 1.0mA max
7 FNC2 I/O Programmable I/O (programmed by FPU), 1.0mA max
8 FNC3 I/O Programmable I/O (programmed by FPU), 1.0mA max
9 FNC4 I/O Programmable I/O (programmed by FPU), 1.0mA max
10 FNC5 I/O Programmable I/O (programmed by FPU), 1.0mA max
11 FNC6 I/O Programmable I/O (programmed by FPU), 1.0mA max
12 5C O 5V DC power supply, 100mA max
13 HR1 O Horn alert signal output, 16.0V/2.0A max
14 HR2 O Horn alert signal output, 16.0V/2.0A max
15 gnd Ground
Thank you.
15 gnd Ground
