Kenwood"TK-940"
rescue1017
Leonard , Texas
Any idea on if this is a good unit or not I have a guy wanting to trade my pro-74 scanner for this "TK-940" would this be a good deal I dont have any way to program it
WayneH
Forums Veteran
Super Moderator
Your master site
800MHz ONLY
The Kenwood TK-940 is an 800MHz commercial radio which will do conventional and LTR. If you only want to listen to 800 LTR systems and conventional 800 channels then the 940 will do fine. The 940s generally go for less than 100 on eBay. What your scanner is worth I don't know but if it is more, don't trade. If it is, trade and resell it.....if it's in good condition.
I have two of these radios so if you want to know more ask...
-Wayne
miserytom
Suffolk , NY
hey wayne, i have the same radio i got from my job, we used to have them in every truck, but now we all have nextel phones, do u know how to program that radio? and is there any way to make it more than a 800mhz radio just for listening purposes, also do u know of any 800mhz freq's that are legal to talk on without a lic.?
thanks in advance
WayneH
Forums Veteran
Super Moderator
Your master site
It's programmed like most any other commercial radio, i.e., it requires a programming cable and associated software. The software is pretty straight forward but setting up LTR systems can be a bit tough at first. And you can set up conventional 800 channels for receive only, no trunking though (you would need to remove the mic). There are no 800MHz freqs available that do not require a frequency. 853.4875 is a common itinerant that some comm shops program in for kicks. Once an area officially rebands that freq will be given to Public Safety though.
rmavrickr
Hi Wayne
where do i get a cable and where do you plug it in to and can i program LADD 1 2 and any other Alberta freqs
thanks
WayneH
Forums Veteran
Super Moderator
Your master site
Hi Wayne
thanks
You can purchase a cable from a Kenwood dealer or via ebay. It plugs in to the mic jack of the radio. And I am not familiar with those radios systems you describe so I can't answer that question of what can or can't.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hi Wayne
thanks
Sorry for jumping on this question Wayne, but as an Albertan, i do have an answer for this one.
Cable can be had on ebay, software your going to have to get from kenwood or an authorized kenwood reseller.
The radio you have is for 800Mhz, Ladd 1 and Ladd 2 are Vhf, this radio CANNOT be programmed for these two channels. to be able to have a radio on Ladd1&2. You are going to need a Vhf(136-174Mhz) Radio.
mavrickr, if you have any other questions please feel free to PM me, as i live in Alberta, and i will answer any questions as best as i can.
