The KRA-25 seems to be Kenwood's "version" of the Laird EXH-155. I have compared one to the EXH-155-MXI that I sometimes use on my Icom F3161, and they appear to be identical apart from the connector.
With that in mind, you could get the EXH-160 instead. It's tuned to 160 MHz, which is basically right on top of the railroad band, so it could have slightly better performance than the KRA-25 which is tuned to 155 MHz. According to the chart I have,
EXH-160-SFU would have the correct connector for the TK-2140.
Don't expect it to work wonders, however. When I use the EXH-155 on my F3161, I do notice a slight increase in received signal strength over the stock VHF antenna, but it is very small. There is a slightly more noticeable increase in transmit signal strength however. The standard Icom VHF antenna seems to do a very good job though, so you would probably see a greater increase in performance over the KRA-22 stubby.
