Kenwood tk3100
KD0NDO
ok so i have this radio got it for 5 dollars. i need to know how to program freqs into it. not the stock 8 which are changeable by turning it on and pushing some buttons. what is this radio capable of? can i use it on the 40cm band? what do i need to program it?
thank you
XTS3000
That radio uses software/programming cable to change the channels, and it will program down to the ham 70cm just fine. If you want to get fancy, you can even add a 2 position switch and turn the 3100's into a 2 channel radio.
KD0NDO
sweet! where can i get the software and the cable, and what will be the cost?
sixmeterdx
So I just picked a pair of these up. What software, and what cable do I need? I also want to program mine for 70CM.
Thanks de Patrick
zsauve
Oak Creek, WI
Thanks de Patrick
You need the KPG-22 cable. It is the cable that has the speaker microphone connector on it. the software you need is the KPG-48D, you can get the software from many places. Kenwood software is SO MUCH easier to get than Motorola and there are no legal issues with having Kenwood Software. The software will reject 70CM frequencies but won't erase 'em and it will write the codeplug without issues and work just fine. Also I should add that the KPG-48D runs under DOS, although I could get it to work under XP in a command window.
Best of luck,
Zack Sauve
