johnboyreb1
My radio is transmitting but no one can hear me. What could be the problem ?
Since the TM-281A is for Amateur Radio, I'm assuming you have an Amateur Radio license. As a licensed ham, you should have a basic understanding of frequency, repeater offset, and PL tones. Have you tried narrowing down those settings first?
Because my handheld recever is showing its receiving but can't hear.
You mean the back-lighting of the display goes dark? If that's happening, I suspect your power supply isn't providing enough current to keep the voltage where in needs to be on transmit. Or, there's something wrong with the power wiring between your power supply and the radio causing a large voltage drop.
Does it not transmit a carrier?My radio is transmitting but no one can hear me. What could be the problem ?
So now you're saying that your HT can pick up a signal from the TM-281a but does not respond to modulation? As posted above, if the HT is in close proximity to the TM-281a, it can be overloaded. It can also pick up a signal internal to the TM-281a that never makes it to the antenna jack. You must have a pretty good separation distance to even try this method.Radio has been working just stopped. You can see the signal bar on others radio just not my voice.y handheld works but not my truck mount.Because my handheld recever is showing its receiving but can't hear.
I think you are getting the sharp questions because you want help and then provide almost no factual information.Actually I've been using citizens bands and vhf radios my whole life so don't know why people have to be rude to others !
If you've never used ham, how do you know the radio quit working. How did you know it worked before?I've never used ham we use them for hunting on private channels.
