Kenwood: Kenwood TM-D710A question
Cleveland, OH
#1
I have a Kenwood TM-D710A radio in my car.
I am unable to change its output power level.
I push the LOW button but nothing happens.
How can I change this?
See the attached image.
KC4YIN
Kinston NC
#2
I have the 710 A right here in front of me. That is how it should work. Just press the "LOW" button repeatedly to cycle through the different power settings.
KC4YIN
Kinston NC
#4
How long have you had the radio in your car? If it's been a while you may need to see if you can open up the head and check the switch. It might be possible to clean it.
