From what I've read, Japanese amateur radio regulations are much more restrictive than elsewhere in the world. As a result, radios made for the Japanese market often have band restrictions "hard-coded" into the CPU and cannot be modified to transmit outside the Japanese amateur radio bands.
A few years ago, I purchased an Icom ID-31 as part of an estate sale. It would not tune above 439.9875 MHz. IOW, it would not tune the U.S. 70cm "repeater band". So, I did a master reset of the radio. The menus all came up in Japanese. That was my clue that I had a Japanese-spec radio. I figured out how to get the menus back to English, but the radio still wouldn't tune above 439.9875 MHz. I sent the radio to a well-known Icom-authorized repair shop to see if they could do anything with it. The shop called me to say that it was a Japanese-spec radio and could not be modified to work on the U.S. band plan.
The moral of this story is don't buy Japanese-spec radios. If you are shopping on E-bay for an amateur radio to be used in North America, the listing will show where the seller is located. If it's Japan, keep shopping. If you are still interested in the radio, ask the seller to show you the radio transmitting on a frequency in the band plan for your country. If the radio won't transmit on frequencies that you plan to use, don't buy the radio thinking that you can modify it to do so. You may be in for frustration and disappointment.
