I was recently given a TR-2500 with three power adapters. One is a disposable battery adapter and the other two are for ac and dc plug in connections. The radio works just fine off of batteries but not off of the ac or dc connection packs. I need to repair these so I can use them. I found the packs cause a fault on the radio when trying to transmit. The power pack is a PB-25 and PB-25H Ni-Cd Rechargeable pack. I opened them up and found the original owner (one I got it from) had worked on the packs. Its a simple setup but all the wires have been changed from their original connection points. Can someone supply a diagram of the packs setup or pictures of the inside of their pack so I can change it back to the way it was. I found an FJ Switch had its wires cut and just sitting inside the pack. Thank you for your help.
