Keyboard Tricks That Work On The BC898T?
rwl48
MA,
Does any know of any Keyboard Tricks That Work On The BC898T? Or other tricks?
Hey Guys... I found how to do CC only and what plan to use on the 898T on Pages 46 & 47 of the BCT-8 manual.Also the EOT info is there. I found all the info for the EIGHT functions except I think #4 which just shows ON/OFF. If you turn this off it will NOT trunk.Hold down 2,4,9 and turn it on and it will tell you what firmware you have. Also the 2,9,manual will reset the radio.
I sat down with the 898T and here is some helpful (I hope) info... After you enter the system you want to program. Turn the VFO knob and you will see EIGHT options.
1 PROG F
2 PROG ID
3 SCN LIST
4 OFF ON
5 S-BIT
6 EOT
7 CC ONLY (PLAN 1,2,3,4)
8 ID LOUT
After you complete one option hit the data button and you will be back at the options. Hope this helps
