OkieBoyKJ5JFG
- Joined
- May 16, 2022
- Messages
- 72
Before I got an amateur license, I ran a GMRS radio in my truck with a Nagoya HDG antenna. This thing is a beast about 48" long and with a fiberglass shell almost an inch in diameter. It allegedly has 6.5 dB gain, and although I didn't have any way to formally test it, it would definitely blast out a signal. SWRs throughout the GMRS band were spectacular -- 1.00 to 1.01:1 all the way up and down. Naturally, when I put a dual-band radio in the truck, I bought the HDA which is the dual-band amateur version of the same antenna. SWRs were terrible -- no better than 5.0 and up to 8.4 throughout the 2m and 70cm bands. I tried it with three different radios on two different NMO mounts and it didn't improve. Figuring I just got a lemon, I sent it back to Amazon in exchange for another one which came today. Same craptastic results. I tested it on a magnetic NMO mount on a steel pizza pan, as I usually do initially when I get a new antenna. Just to be sure, I screwed the HDG onto the same mount and it was once again about perfect as SWR readings get, so it wasn't the radio or the cable or the mount causing the problem. I'm just baffled about how they could get one so right and the other so wrong. Pretty disappointed, to say the least.
