Kinetic Avionics Latest version of Basestation released! (V1.2.3.159) for SBS1 users.
http://www.kinetic.co.uk/estore/index.php?_a=viewCat&catId=7
Forum:
http://www.kinetic-avionics.co.uk/forums/viewtopic.php?f=9&t=13934
This is a full CD file (14MB) in Zip format. To download it you must either register on the eStore (which I recommend) or provide a valid email addreess. After proceeding to Check Out you should receive two emails, one acknowledging your order, the other with the link to download the CD file.
I'd save the Zip to a new folder and extract the files to that folder. You may want to backup your existing Basestation folder or selected files.
Close Basestation and then run Setup. It all worked here just fine.
The Zip includes a full Release Note (ReleaseNotes.txt) which includes all version history.
New Functionality
* Supports audio streaming of the SBS-1eR internal radio interface using RTSP and RTP/UDP network protocols. See the Built-In Radio section of the reference manual for details
* No longer requires a license key to use the external radio interface
* Added a new menu option:
Settings > Reload > Flags to reload the countries, country flags and operator flags
* New settings to enable the processing of TIS-B, ADS-R and non-ICAO 24-bit addresses.
See the description in the Data Settings section of the Reference Manual.
* No longer requires a restart of BaseStation when switching between USB and network connection, or when changing network parameters.
Fixes
* Changed the default colours for the "user" outline types to ones that better suit the hi-res outlines.
* Improved the handling of squawk codes and callsigns for non-ADS-B aircraft to reduce the likelyhood of assigning a
code to the wrong aircraft.
This is because these codes are obtained from Mode-S radar surveillance replies which have less built-in error checking than ADS-B messages.
* Different handling of non-ICAO addresses in order to avoid database errors.
