KMC-9C Desk Mic Monitor Switch Mod?
Disp46
Anyone familiar with a mod that can disable the monitor switch so that you do not have to depress the monitor button before you can depress the transmit switch?
ramal121
Lots and lots of watts
Calif Whine Country
Yes, it's easy. Take the four bottom screws out (under the rubber feet) and wedge the bottom plate open in the front just enough to get some needlenose pliers in there. In front of the transmit/monitor levers is a metal bar, about 1/4" and as wide as both levers. Grab the end of the bar with the needlenose and twist it back and forth until you get it to pop out. Put the screws back in and you're good to go.
