KNG2-P150 Group Scan feature/setting
BlueDevil
WA
I finally got my hands on a KNG2-P150. I am trying to figure out how to enable the group scan feature or setting. In the programming menu there are several different scanning options and features however I am not seeing anything that clearly says or is titled Group Scan. I am assuming that it is included in this radio like every other BK radio.
Can anyone offer any help?
CryptoBoy
I assume you are using RES to program your G2? You cannot change menu items or zone scan settings by using keypad programming, you must use RES to do this. That said, in RES you will want to add a menu item for zone scan select and then you can use this menu item to select which zones you want to include in your zone scan. You probably want to set a button or switch for zone scan on/off as well. And note that under normal circumstances, zone scan is a modifier of channel scan, so channel scan must be on for zone scan to work, although there is an option (I forget which one) that allows zone scan to turn on channel scan automatically. It's a bit complicated because there are so many options surrounding scan, but the good news is that it can do whatever you want if you can figure out how to make it do it.
BlueDevil
WA
Thanks for the help. I was able to find the proper settings in RES.
