KPG-D1N Software Importing Read file into existing File
K7MEE
Priest River, ID
Our agency uses NX-5200 Series Portables. An agency in a neighboring county uses the same radio. We are trying to program some of each of our counties frequencies into each others software programming. I can read and write to their radio fine. However, I don't get the option to export or import anything. And, opening the software into 2 separate windows to drag and drop doesn't work either. Anyone ever done this and able to give some assistance?
danielxgame
calgary
i think your issue is to import or export from digital to analog, kenwood program are not same like excel file that you can copy and paste.
in my experience in digital and analog programing, you can export/import analog to digital but digital to analog no luck.
BearcatUSA
PL-259 Connector Fan
Wilmington, DE
KPG-D1 has no Import/Export at all!
This is one the most terrible things in NX5K for now. In some particular windows you can do copy/paste inside one app. Somewhere you can do copy/paste even between Excel, but not everywhere. For example, P25 trunking frequencies, NXDN trunking frequencies, trunking GIDs, etc., cannot be copypasted with any external app. Even more, D1 might stop working and exit accidentally if you try to do that (with data loss).
I spent a lot of time on migration from NX200/NX300 radios, as well as creating different 'codeplugs' fir mobiles and portables.
Data import/export absence in D1 is really annoying!
danielxgame
calgary
i think you are wrong there's import in D1, maybe update your firmware im using 1.71. i import file from NX-700 file to 5k series.
danielxgame
calgary
i forgot to mention about import.. you must set up first the D1 product information select the model you need, then in in ZONE-CHANNEL format used- CHANNEL TABLE not the personality , if you select personality the import will not activated. hope will help
kd4efm
EL98 Florida
Import has been in D1 since day 1.
Export no, but it will export to an html doc the entire codeplug.
I have imported from 111d and 141 with little
Issue. D3, yeah, that's a beast, but D1, I have done 100+ imports from 111 and 141.
Sent from my SM-G965U using Tapatalk
