KPG44D mod to 6M
wcu02mpa
Asheville,NC
#1
I have searched in vain for the hex-edit procedure for the KPG-44D. I prefer this method as it is straight forward from the other methods I have seen. I prefer direct frequency entry. I am proficient with hex-editing as I have done this to both to the Motorola waris series (I have both 6M and 10M loaded on CDM-1250's) and the Vertex VX4000-5500-6000 series of software. Which file in the KPG-44D requires the hex-editing? Also I am using the windows based version, but have the DOS based if that is the one used.
I have the KPG-44D open in program files but am not sure which one.
New Orleans region
#3
I found the info. Here is the link for anyone else interested.
http://www.rogercoulson.com/WA1NVC/TK-690on6m.pdf
This method works well, but requires you to just about print out the hex file to locate all the locations for the different channels you want to put on 6 meters. Have done it on several radios with good results.
Roger has been a good source of information like this over the years.
wcu02mpa
Asheville,NC
#4
Last night I successfully performed the 6M modification for the TK-690. I think what helps the most is to understand the hex editing procedure (oh and a service monitor is a must). My next one to try is the low split 690 and put it into the 10M band.
KC2GSP
#5
The program by n2mci works terrific for putting the low split on 10 fm. It literally works in seconds
